Hi, I am using STM32F769I-DISCO.In SDK I am Using SDJPEG example. In the code File open function is working fine but file closing is not working. Can anyone sort out this issue?
DM.14
FBL
Hello @DM.14​,
Do you refer to this example? If yes, could you make sure that HAL_JPEG_GetInfo is retrieving the image parameters properly?
Best regards,
FBL
