Help QuadSPI interfacing with MX25R6435F on B-L475E-IOT01A
Aadi__
Visitor
I am developing an audio recording application that captures audio from a MEMS microphone, stores the data in DMA, and saves it as a .wav file using the QuadSPI protocol. I have integrated the FatFS middleware for file system management. While the code compiles without any errors or warnings, my PC fails to recognize the mass storage device when I attempt to read the recorded data.
SofLit
So the problem is not related to the CubeIDE/Mx nor to the QSPI interface/Flash memory it's more related to the USB usage.
Could you please elaborate more and be concise in your question as the title and the issue description are different?
PS: moved the thread to MCU products and edited the label.
Thank you
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
FBL
Hi @Aadi__
Could you specify where exactly do you see the issue while reading recorded data? Did you try to isolate the issue by simply using USB MSC functionality alone?
