Has Anyone Successfully Implemented Micro-ROS UDP on STM32F7?
sahan_s
Visitor
Hi everyone,
I am trying to implement Micro-ROS over UDP on an STM32F7 (Nucleo-F767ZI), but I keep running into hard fault errors. I am using LWIP with FreeRTOS in STM32CubeIDE.
So far, I have:
  • Successfully built and integrated Micro-ROS into my project using serial transport.
  • Configured LWIP for UDP and able to ping the board.
  • Initialized Micro-ROS with a UDP transport, but the system crashes with a hard fault.
Has anyone successfully gotten Micro-ROS over UDP working on an STM32F7? If so, could you share:
  1. Any specific LWIP settings that need to be changed?
  2. The correct way to handle memory allocation (heap/stack sizes) for Micro-ROS?
  3. Debugging tips for tracing the cause of the hard fault error?
Any insights or working examples would be greatly appreciated!
Thanks in advance!
1 REPLY 1
