HAL_UART_DMA_Receive problem
Arman Ilmak
Hi guys.
I have a problem with this hal function.The problem is that every time I use this function the first byte received is not what I transfer to it.For example when I send AT (ESP8266 AT command) to the module it must return AT OK,but every time(except the first time)the first byte is not A!
https://imghostr.com/KHNQXNw1P
10 REPLIES 10
S.Ma
Principal
