HAL_RTC_GetTime - Problem for increment the count according to seconds
Param sivan
In one of my task, i just increment a one seconds counter variable after read HAL_RTC_GetTime  and compare the read seconds value is change or not. It doesn't work until I comment the following line in the HAL_RTC_GetTime  function as described in one thread in the forum. What is the cause? How do I resolve this issue ? Thanks in advance.
sTime->SubSeconds = (uint32_t)(hrtc->Instance->SSR);
Thanks,
Param.
Piranha
Chief II
waclawek.jan
As Piranha said above: read date after reading time, or set RTC->CR.BYPSHAD.
Param sivan
Thank you. It solved my issue.
