freertos + flashwrite gives hardfault
SOZKA.1
Hii all,
ım using stm32f103c8t6 and trying to implement freertos project,
i have flash write function and it work very well but when i use it in freertos project, if ı call write flash func before vTaskStartScheduler it is okey but after vTaskStartScheduler from any of task it gives hard fault.
what can go wrong
it tried tasksuspend , taskenterritical, disable_interrupt but none of them helped,
any sugestions, thanx s
Hello @SOZKA.1​ ,
Can you share the example so I can reproduce your issue ?
Thanks in advance.
Walid
