2022-08-10 5:02 PM
Using the STM32L4S5 Discovery Kit board (B-L4S5I-IOT01A), I have gone through the sample CMAKE getting started projects from Microsoft as well as tested the STM32Cube IDE sample projects. Both packages appear to be developed by ST. The CMKAKE version actually sends data to Azure IoT Central from the sensors. The IDE samples only simulates data. With STM32Cube IDE, I was able to create a simple Azure RTOS project to send Hello World for standard output.
Re-creating the sample projects for the Discovery Kit to connect to Azure IoT Central and send temp data from the HTS221 is unclear. The IDE samples don't have .IOC files to understand what components where added.
2022-12-26 8:58 AM
Hi @SLimi.1
have a look at this repo: https://github.com/STMicroelectronics/Azure-cloud-samples
it contains a demo connecting the STM32L4S5 DK board to Azure Cloud.
Hope it helps.
regards
Haithem.
