simone23
Visitor II
January 27, 2016
bootloader vs sdram stm32f429
  • January 27, 2016
  • 0 replies
  • 508 views
Posted on January 27, 2016 at 10:02
I'm designing a board that uses the micro stm32f429 . I am considering to use the bootloader CAN integrated and at the same time a memory SDRAM using the FMC . I'm in trouble because the pin PB5 is the CKE pin of the SDRAM and also the rx pin of can2 used in bootloader . There is no possibility to remedy the problem or is it impossible to use the bootloader in CAN bus mode with a SDRAM memory?
#stm32f4-bootloader-sdram
