Are there any application examples for H7 using the ThreadX Module component?
GreenGuy
Lead
See this link:
https://learn.microsoft.com/en-us/azure/rtos/threadx-modules/chapter1
Would like to explore the options of using this method to partition code.
GreenGuy
Lead
Yes, this is what prompted my look at if CubeMx supports the feature selection. Sadly, ST has not worked on this. However there is an example in git called B-U585I-IOT02A_MODULE_MANAGER_THREADX.
The MOOC only makes mention of ModuleX but does not go into any detail.
4 REPLIES 4
GreenGuy
Lead
The first thing I notice is that the Software Packs>Select Components in CubeMX does not include Modules in the ThreadX section. However, the needed txm_module.h is present in ...\STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-AZRTOS-H7\3.1.0\Middlewares\ST\threadx\common_modules along with the other files needed.
I guess CubeMX does not currently support adding Module support to the project.
FBL
Hello @Community member​,
Check this wiki about ThreadX
Introduction to THREADX - stm32mcu
I will let my colleague check if CubeMX is supporting middleware.
Best regards,
FBL
Ghofrane GSOURI
First let me thank you for posting.
I advise you, to get inspired form the steps described in this workshop: MOOC - Azure RTOS step by step workshop
Thx
Ghofrane
GreenGuy
Lead
