Are HAL_ppp_MspInit functions the only place to initialize low level resources?
‎2019-04-18 2:11 PM
Hi everybody.
I'm met several scenarios in which the use of HAL_PPP_MspInit
would be too constraining.
A typical example is when I'm making a reusable library that needs
some peripheral. If I initialize the low level resources for the peripherals
used by the library in HAL_PPP_MspInit functions, then the application code
won't be able to use them anymore.
I've always initialized the low level resource before calling HAL_PP_Init and
it has always worked. But I would like to have your confirm that I'm doing is legitimated.
- Labels:
STM32Cube MCU Packages
‎2019-04-18 3:31 PM
Yes is it reasonable and legitimate to do clock and pin initialization elsewhere prior to usage.
‎2019-04-18 3:31 PM
‎2019-04-19 1:15 PM
Thank you very much for the answer!
