About USBD_HID_SendReport
โ2024-01-28 11:26 PM
The value returned from USBD_HID_SendReport always returns USBD_FAIL,
What settings are wrong?
We think we am doing the settings in project.ioc correctly.
[IDE]STM32CubeIDE 1.14.0
Connectivity -> USB_OTG_FS -> [Mode]Device_Only
Middleware -> USB_DEVICE -> [Class For FS IP]HID
[board]โ NUCLEO-F446RE
โ2024-01-31 1:31 AM
Hi again @pass3master
You need to dig deeper and diagnose clock duty cycle, also, you need to check the packets using USB Analyzer.
โ2024-01-29 12:39 AM
Hello @pass3master
Have you tried this example STM32CubeF4/Projects/STM32F446ZE-Nucleo/Applications/USB_Device/HID_Standalone at ec8744184587ef76b0e1704d1ee3e391f1aa2b90 ยท STMicroelectronics/STM32CubeF4 (github.com)
It uses remote-wakeup through key button
โ2024-01-30 12:26 AM
No, I have not tried.
We think it is a similar function, but my question was not answered.
When is USBD_FAIL returned from USBD_HID_SendReport?
ใปIs Pinout & Configuration wrong?
ใปClock Configuration is wrong?
ใปIs NUCLEO-F446RE not allowed to be connected via microUSB?
โ2024-01-30 1:52 AM
The USBD_FAIL status can be returned from USBD_HID_SendReport under several conditions.
It can occur if the USB device is not properly initialized, if the class is not correctly registered, or if the device process does not start correctly. More likely, the clock could potentially cause this problem with the USB communication.
โ2024-01-30 4:09 PM
We have verified that Error_Handler is not called in the following process.
void MX_USB_DEVICE_Init(void)
/* Init Device Library, add supported class and start the library. */
if (USBD_Init(&hUsbDeviceFS, &FS_Desc, DEVICE_FS) != USBD_OK)
Error_Handler();
if (USBD_RegisterClass(&hUsbDeviceFS, &USBD_HID) != USBD_OK)
Error_Handler();
if (USBD_Start(&hUsbDeviceFS) != USBD_OK)
Error_Handler();
If so, does this mean that the clock is the problem?
Where can we find out if there is a clock problem?
โ2024-01-31 1:31 AM
