Where can I buy ST Link V3 mini cables?
LMI2
Lead
ST link V3 Mini uses dense 10 lead cables.
Ebay doesn't find anything suitable and Digikey has some I think, but it is expensive to order just some cable.
This I think is one
https://www.digikey.fi/product-detail/en/adafruit-industries-llc/1675/1528-2009-ND/6827142
My bad. The 1.27mm pitch is less common, but it's not that rare anymore.
Here's a 14-pin 1.27mm pitch:
https://www.amazon.com/gp/product/B07FVHPMQB?pf_rd_r=QXPK0GEQGG2YJT15GEV0&pf_rd_p=edaba0ee-c2fe-4124-9f5d-b31d6b1bfbee
4 REPLIES 4
It uses 14-pin cables, not 10-pin. A 10-pin cable won't plug into the header on the board.
Found a bunch on Amazon:
https://www.amazon.com/Sydien-2-54mm-Connector-Ribbon-Length/dp/B07Q2SMN9H/ref=sr_1_3?dchild=1&keywords=14+pin+ribbon+cable&qid=1593607294&sr=8-3
Uwe Bonnes
Principal III
The amazon part seems to be 2.54 mm pitch . You need 1.27 mm pitch!
LMI2
Lead
That is the problem, tighter pitch connector are not so common. A local store found something on Distrelec, in a couple of days we'll see if they fit.
14 pin it will be.
