UART_HyperTerminal_IT Example on STM32N6570-DK Board - Debugger can't connect
‎2025-03-14 5:08 AM - last edited on ‎2025-03-14 6:21 AM by Andrew Neil
I built and debugged the default example UART_HyperTerminal_IT using the STM32N6570-DK board, but the following error occurred. How can I resolve this issue? I am using the latest versions of ST-Link and all related software.
STMicroelectronics ST-LINK GDB server. Version 7.10.0
Copyright (c) 2025, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
Waiting for debugger connection...
Debugger connected
Debugger connected
STM32N6 series
‎2025-03-14 5:28 AM
Hello @wwnsok2
Do you changed STM32N6570-DK in DEV_BOOT mode to be able to debug it?
Check UM3300 section 7.7 Boot options
https://www.st.com/resource/en/user_manual/um3300-discovery-kit-with-stm32n657x0-mcu-stmicroelectronics.pdf
You can also you refer to this post:
Best regards,
Romain,
‎2025-03-14 6:12 AM
‎2025-03-14 6:29 AM
@wwnsok2, the capture you shared doesn't help.
Can you confirm you configured BOOT0 and BOOT1 switch on STM32N6570-DK as the picture bellow:
Then, press one time on NRST black button, LED2 Red must be ON and it confirms that STM32N6 is in DEV_BOOT mode. After that you can start a debug session.
Best regards,
Romain,
‎2025-03-14 10:35 AM
