The device is protected
TrungNguyen
My MCU is loaded with the test program at the supplier. But when I loaded the actual program, it did not allow me to erase or read the chip, and the device was protected.
4 REPLIES 4
Stecklo
Senior
There seems to be some option bytes programmed to protect the example code. Probably it's RDP == 0xBB. Setting it to 0xAA will allow you to flash your code, but the original demo will be erased forever
I did that and still couldn't.
Very little detail of board or connectivity.
Could be a connection issue.
Please try using the ST-LINK Utilities or STM32 Cube Programmer applications.
Describe the board.
Had success with this previously, or new board/design?
Does mass erase clear the RDP state?​
TrungNguyen
I got it to thank you.
