Starting PROFINET Stack Development on STM32
‎2024-09-16 9:36 AM
- Do you have any suggestions on how to start developing or integrating a third-party PROFINET stack on an STM32 evaluation or discovery board?
- I would like to create my own application for a PROFINET master and slave.
- If there are any example codes available, that would help me understand quickly
Thanks regards
siva
STM32F7 Series
‎2024-09-19 4:50 AM
ST doesn't provide any example. You need to contact our partnumber port-automation.com
so they can provide you a such example. Otherwise as said previously, look for any other open source implementation on the internet.
‎2024-09-16 12:15 PM
Depends on your previous experience with STM32F7 or other STM32's with ethernet. Especially the ethernet.
‎2024-09-16 12:40 PM
Our Third-party port-automation.com offers a such stuck: https://www.st.com/en/partner-products-and-services/port-profinet.html
Otherwise, you can search it in the net. For example: https://github.com/rtlabs-com/p-net
‎2024-09-19 4:42 AM
- I have decent experience with Ethernet and the STM32F7 microcontroller.
- I would like to develop a PROFINET application, including both master and slave functionalities.
- Any examples or resources you could provide to help me understand the development process from the stack to the application would be greatly appreciated.
Thanks & regards
siva
‎2024-09-19 4:44 AM
If there are any examples available that demonstrate both the stack and application on a single platform, it would greatly help me understand the development process.
Thanks & regards
siva
‎2024-09-19 4:50 AM
