I am trying to flash a hex file on a Raspberry Pi (Debian Linux) via a ST-Link/V2.
Here it fails however already with the installation of the STM32CubeProgrammer for Linux. At step6 I get the error:"File or directory not found" with the following details
2022-11-08 12:13 AM
com.izforge.izpack.api.exception.IzPackException: An error occured
- in java.lang.Thread.run() at Thread.java:748
- in com.izforge.izpack.installer.unpacker.UnpackerBase.run() at UnpackerBase.java:241
- in com.izforge.izpack.installer.unpacker.UnpackerBase.unpack()
at UnpackerBase.java:319
Caused by: java.io.IOException: Failed to create temporary file for
/usr/local/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/libstp11_SAM.so.conf in directory
at UnpackerBase.java:299
at UnpackerBase.java:479
- in com.izforge.izpack.installer.unpacker.UnpackerBase.parseFiles()
at UnpackerBase.java:934
- in com.izforge.izpack.installer.unpacker.ScriptParser.parse()
at ScriptParser.java:96
Caused by: java.io.IOException: Datei oder Verzeichnis nicht gefunden
at ScriptParser.java:92
- in java.io.File.createTempFile() at File.java:2063
- in java.io.UnixFileSystem.createFileExclusively() at
UnixFileSystem.java:-2
What is the reason for this?
- Labels:
ST-Link
