for STM32F405RGT, is the VSSA and VSS connected internally on the chip? Should I need to connected them externally ?
JieHong Mai
Connect everything properly externally.
Make sure you have a pull-down on BOOT0
JieHong Mai
I tested the resistance between VssA and Vss of STM32F405RGT using multimeter, I found it was 8 ohms.
That's great, but what's the need to half-**** the PCB design and not connect everything properly?
