Firmware
snehadakhare01
Hi, i have build up  Normal mode program For CAN on  board (stm32f103c8t6) setup. It is showing that data is transmitting but when I tested on board there no Data
Can you tell me what is the problem??
This isn't a magic show, you'll need to present your software and hardware in a way others can understand what you have created.
CAN will need a transceiver to get to a bus, and the bus will need a responding device also attached to it.
In Loop-Back mode you could use a scope on the CAN_TX pin to see a signal.
4 REPLIES 4
snehadakhare01
I have created bus to
snehadakhare01
The board I am using it will not work for loopback mode
Still seems to lack any material presentation of what you're doing
