Extend STM32N6570-DK with a WiFi module & Zephyr
mtv
We need to add WiFi connectivity to an STM32N6570-DK board and run Zephyr on it.
Is that possible? Can you propose a solution?
We have seen X-NUCLEO-67W61M1 expansion board that can work with STM32N6. But can that board be connected with the DK board?
Thank you very much for any suggestion.
Regards.
4 REPLIES 4
Andrew Neil
Of course it can - just connect appropriate pins for SPI, UART, GPIO ...
You will have to check the User Guides and/or schematics of both boards to find appropriate available pins.
  • User Guides will be on the 'Documentation' tabs of the respective Product Pages;
  • schematics will be on the 'CAD Resources' tabs
Thank you for the quick response.
What about the software side? Any clue what would be needed to run zephyr?
You'd need to go to the Zephyr site for that:
https://docs.zephyrproject.org/latest/boards/st/stm32n6570_dk/doc/index.html
https://docs.zephyrproject.org/latest/samples/net/wifi/README.html
Getting started on Zephyr is a non-trivial journey:
https://www.st.com/content/st_com/en/ecosystems/stm32-mcus-in-the-open-source-software-ecosystem/zephyr.html
However, with some effort it is possible, correct?
Otherwise a FreeRTOS implementation is more easy to implement using X-CUBE-ST67W61.
Have I understood it correctly?
