Can I control the X-NUCLEO-LPM01A board by programming to decide if supply to the connected boards?
GLiu.2
Andrew Neil
Please explain what you mean by that?
Details of the protocol over the serial port are in the Firmware User Guide for the board, UM2269.
I mean, Does the board can measure a peripheral board current, right? Now, I want to make it to be a power switch for a peripheral board.
And, the "power switch" can be controlled by programming, e.g., it can power on/off regularly. Is it clear?
Gaosheng
"Does the board can measure a peripheral board current, right? "
What do you mean by "peripheral" there?
"I want to make it to be a power switch for a peripheral board. And, the "power switch" can be controlled by programming,"
Did you not look at the document I mentioned?
See the Product Page: https://www.st.com/en/evaluation-tools/x-nucleo-lpm01a.html
Yes, it can certainly do that.
