2020-08-23 10:10 AM
Hi all,
is it possible to connect an external antenna to the X-NUCLEO-NFC06A1, if possible, where?
Thanks,
D.
2022-11-30 4:15 AM
Hi @Jørgen Greve ,
There is no possibility to add additional components for the new antenna, as there is no spare/free pad.
You will need to replace the existing matching components with the ones to make it suitable for the new antenna.
Best regards
