2018-11-22 7:44 AM
I'm designing the NFC antenna, the EMC filter and the matching circuit, for an industrial NFC application. I'm looking for a good value of the matching impedance that provide the right tradeoff between performance and efficiency
2018-11-23 12:09 AM
The target matching impedance is commonly chosen by the available power budget - the power you want to spend when the reader is transmitting.
If there is no special power budget defined and there are no special requirements about read range, then a good target is around 20 to 30 Ohm. This should give a power consumption between 170mA and 140mA during constant wave.
Br Travis
2018-11-23 12:09 AM
Br Travis
