STM32L -> I2C -> M24LR16E
jesperhede
Posted on November 19, 2014 at 00:22
My ANT1M24LR16E does not seem to repond to my I2C commands.
After the Send7bitAddress it reponds with a NACK (SDA high on one SCL clock). This is the first time I'm writing to it. Any ideas on why it is not working?
/* Turn on M24LR16E */
GPIO_HIGH(GPIOD, GPIO_Pin_2);
Delay(100);
//x10ms
/* Generate start condition */
I2C_GenerateSTART(I2C1, ENABLE);
while
(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)){}
//Wait until bus is free
/* Send device select+read/write cmd and wait for ACK */
I2C_Send7bitAddress(I2C1, 0xA6, I2C_Direction_Transmitter);
//0xA6 = 0b10100 Page 18 datasheet
while
(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)){}
/* Send address byte. Wait until data has been received */
I2C_SendData(I2C1, 0x00);
//Register
while
(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)){}
I2C_SendData(I2C1, 0x2A);
// Data to be written
while
/* Generate Stop condition */
I2C_GenerateSTOP(I2C1, ENABLE);
Delay(100);
while
(1){}
/* Shut down M24LR16E */
//GPIO_LOW(GPIOD, GPIO_Pin_2);
//Delay(100);
#stm32l-m24lr16e-i2c
Posted on December 08, 2015 at 17:28
Hello
-> for STM32L i2c library (Hold library, please use Cube library), the 7bit format I2C_Address byte (0xA6 ) has to be written 0x93 (shift 1 bit @ right).
This is the reason why the device doesn't ACK to Device Select request.
In addition, reading your code, there is a mistake on
Send address byte
part of your code : the M24LR has 2 address bytes.
To help you to complete your program, this is in attached file, ,an example of I2C code for STM32L.
But again, please, uses CUBE platform, easier to compile and use.
Best regards
ST NFC customer support
Delay(100);
//x10ms
while
while
//Register
while
while
Delay(100);
while
(1){}
//Delay(100);
________________
Attachments :
I2C_M24LR04E-R.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzMN&d=%2Fa%2F0X0000000bKU%2FAxJ1h1LeSGIBW7EXI4mSxkvsxEdMmA2E4MlIpXmBQAM&asPdf=false
Hello
Send address byte
Best regards
Delay(100);
//x10ms
while
while
//Register
while
while
Delay(100);
while
(1){}
//Delay(100);
________________
Attachments :
