2021-11-22 05:52 AM
We have an pluggable antenna connected to a ST25R3911B. We need to find an efficient way to detect when the antenna is plugged/unplugged. What is the best way to do that?
2021-11-22 08:57 AM
Hi Javier,
you measure amplitude and phase of the antenna and compare them against known good values. This among other diagnostics are also discussed here: debugging-st25r3911b-loss-of-sense-range.
Best Regards, Ulysses
2021-11-22 08:57 AM
Hi Javier,
