Anthony Rabine
ST25DV discovery not working with ST25PC software
  • October 18, 2019
  • 6 replies
  • 1141 views
I have bought an ST25DV Discovery kit but it cannot be used with the ST25PC software, it says that the IC does not support *** feature.
Hint: when I read the UUID, I have Hitashi as manufacturer (byte 2 is 0x03 instead of 0x02 as indicated in the datasheet).
   [DEBUG] FC
   [DEBUG] 67
   [DEBUG] FB
   [DEBUG] 4
   [DEBUG] 0
   [DEBUG] 25
   [DEBUG] 3
   [DEBUG] E0
Do you know what's going on?
    Hi Anthony,
    could you please say if you read the same UID from another application (Phone app for example) ?
    Thank you,
    Damien
    Anthony Rabine
    Yes absolutely, I can read the same with the NXP RFID tool on Android (and it also says that it comes from Hitachi). Looks like the ST25DV is not an ST design :)
    JL. Lebon
    ​Dear Anthony,
    Yes this value of IC manufacturer code is not correct.
    Is it possible to tell us the origin of this ST25DV discovery board ? Where and when did you acquire it ?
    This would help to understand what's going one.
    Thank you and best regards.
    Anthony Rabine
    Yes, we bought it on Farnell on 5 sept. 2019
    Réf.Farnell France : 70042712
    Date de la commande :5 sept. 2019
    https://fr.farnell.com/stmicroelectronics/st25dv-discovery/kit-de-decouverte-tag-nfc-rfid/dp/2761534
    Anthony Rabine
    Do you have any clue on that point?
    Anthony
    JL. Lebon
    ​Hello Anthony,
    I have contacted you by private message on this topic 2 months ago, proposing you that you send back to ST the defective part for analysis. Did you see this message and did you sent anything ?
    Best regards.
