2021-07-30 07:18 AM
I am a newbie to the field of RF communication. I am planning to design an antenna using the ST25TV IC. Ultimately, I want to measure the Received Signal Strength Indicator (RSSI) value of the RF communication. I am thinking of using the ST NFC Sensor app on either Android/iOS as an NFC reader for this purpose. I noticed that in the app description, they do mention that the data the app collects can be exported as a .csv file. Does the exported data contain the RSSI values in either Android or iOS versions of the app?
2021-08-02 07:14 AM
Hi VSoni.1,
which RSSI do you mean? There are actually two involved:
Best Regards, Ulysses
2021-08-02 07:14 AM
Hi VSoni.1,
