2026-05-02 10:45 AM - last edited on 2026-05-13 7:44 AM by Andrew Neil
Dear ST colleagues,
I tried recently the package X-CUBE-NFC12.
First I tested on NUCLEO-L476RG board the delivered example and it was working out of the box, then I tried on NUCLEO-C071RB but it was not working, first I noticed that the Pins configuration are not correct it was fixed, but still not working, did anyone ever test this example, because I assume it needs to work without any modification.
Thank you in advance for your support.
Best regards
Bassem Taamallah
2026-05-04 2:40 PM - last edited on 2026-05-05 12:10 AM by Ulysses HERNIOSUS
I guess this is due to the polarity of the user button on NUCLEO-C071RB vs. NUCLEO-L476RG (active high vs. active low)
Rgds
BT
