NFC Tap App iOS
‎2018-01-10 4:53 AM
I'm working wiht the M24LR16E dynamic tag in my application and tried to read this tag with your iOS App NFC Tab. In your user manual
UM2274 this tag 5 type is listed that the app can read out NDEF text. For test I used the M24LR-discovery kit and used this tag
But I can't read out the tag with my iPhone 7. The Display of the tag of the M24LR-discovery kit shows the NDEF Message when I hold the phone to the antenna but the app can't read the tag. Why it's not possible to read out the tag? What can be the reason? Best Regards Eckartds
‎2018-01-18 6:35 AM
Hi Eckart,
sorry for my misunderstanding...I thought it was M24LR16.
I have just tried again with two M24LR
-discovery boards, and it works fine with iPhone7.
Please, could you share the values of CC File of your M24LR-discovery ? you will need an Android Phone with the ST25 Application.Normally, your CC register (4 bytes @Address 0) should be 'E1 40 40 05'.
We have seen that, in production, the M24LR-discovery were not programmed well and contained CC = 'E1 40 FF 05'. So, it you tried to read M24LR just after unpacking it , it could explain the issue.
In this case, I suggest you to reprogram correctly the CC file with the ST25 Android Application.
Let me know.
Br,
Vincent
‎2018-01-11 12:38 AM
Dear Eckart,
M24LR16E is not supported yet by iOS coreNFC , as it uses the protocol extension flag which is not handled in coreNFC. For tag type 5, iOS supports only tags <= 4Kbits.
Regarding UM2274, you're right : this is unclear.
M24LR series Dynamic NFC Tags
M24LR04E products, X-NUCLEO-NFC02A1 and M24LR Discovery kits'
We'll correct and clarify that.
Hope it helps.
Vincent
‎2018-01-16 7:50 AM
Hi again Eckart,
Typo fix. iOS support only tags <= 8Kbits !!!
Br,
Vincent
‎2018-01-18 2:12 AM
Hi Vincent,
I know the supported tag size of 8 Kbits.
But the question is why the tag of the ML24LR-discovery board with the M24LR04E type can not be read by a iOS device.
This memory size is only 4 Kbits.
That's my problem.
Regards Eckart
‎2018-01-18 6:35 AM
Hi Eckart,
Let me know.
Br,
Vincent
‎2018-01-18 6:58 AM
Hi Vincent,
that was the error. After setting the CC register to 0x40 I can red out the Tag without problems.
Thank you.
Do you know if the 16 Kbit type will be supported by iOS in future?
Regards Eckart
