2017-08-08 7:04 AM
Do you have CADSTAR 17 or lower footprint for either the 14x14mm square single sided or the double sided PCB version. I am working on a four layer design so a four layer coil or using any two or three layers design would be acceptable.
It is for M24LRxx IC.
DXF file format may also be acceptable?
#m24lrxx #14x14mm-coilSolved! Go to Solution.
2017-08-11 1:33 AM
Quadrasol who support CADSTAR in the UK have helped me with a PCB foil pattern that I can paste as a shape or wires. I can go with that but I was hoping to make a Library part with a symbol and footprint.
2017-08-08 1:56 PM
I have posted a follow up question elsewhere about the relative performance of the various reference designs.
2017-08-11 1:33 AM
