NFC as wireless EEPROM memory
David.Cheng
HELLO ALL! i want to do point to point (P2P) data exchange between the NFC and a smart phone,
Im new to NFC, require 64Kbyte EEPROM and mcu can write it, how to choose the chip
Brian TIDAL
See our various demos with dynamic tags:
Getting Started NFC: ST25DV discovery kit smartphone demo
Getting Started NFC: ST25DV discovery kit demonstration using ST25R3911B reader
if you want to prototype an application based on dynamics tags, you can use the following Discovery kits:
  • ST25DV-DISCOVERY Discovery kit for ST25DV04 Dynamic NFC/RFID tag IC with fast transfer mode capability
  • M24LR-DISCOVERY Discovery kit for CR95HF Reader & M24LR04E Dynamic NFC / RFID Tags with energy harvesting
  • M24SR-DISCOVERY Discovery kit for the M24SR series - Dynamic NFC/RFID tag
Rgds
BT
5 REPLIES 5
Brian TIDAL
if my understanding is correct, you would like something like this:
MCU <---Local Interface---> Tag <--- RF interface ---> Smartphone
i.e. a tag with an NFC interface (communication with a smartphone) and with a local interface for communication with an MCU
In such case, you can use the following products
  • ST25DV64K if you want ISO/IEC 15693 products (Long Range) supporting a Fast Transfer Mode through a Half-duplex 256-byte dedicated buffer
  • M24LR64E-R if you want ISO/IEC 15693 products (Long Range)
  • M24SR64-Y if you want ISO/IEC 14443 products (Short Range)
Those products can be operated from an I2C interface or by a 13.56 MHz RFID reader or an NFC phone. The I2C interface uses a two-wire serial interface, consisting of a bidirectional data line and a clock line. It behaves as a slave in the I2C protocol.
See ST25 Dynamic NFC tags product selector web page on st.com.
Rgds
BT
the idea is that mcu writes data to nfc, phone reads the data via NFC
Brian TIDAL
Rgds
BT
thx, can dynamic tags store more than 64KB data?
Brian TIDAL
​Current products can store up to 64Kbits (8 Kbytes)
Rgds
BT
#[ST25 NFC/RFID Tags and Readers]​
