M24LR-DISCOVERY SW documentation
sasa
Posted on October 10, 2016 at 12:42
I am trying to create an application SW using M24LR-DISCOVERY using RF transceiver board to read devices containing M24LR dual eeprom, but I am struggling to get the documentation to implement functions like the M24LR-DISCOVERY SW has like auto-detect, read memory from - to.... etc.
The only documentation I've found are AN3375  Application note and AN3163 Application note.
Is there any docs explaining which function and which parameters I need to use to get any result.
example: detect and read from EEPROM address 0x15
 - CR95HFDLL_USBconnect()
 - CR95HFDll_SELECT()
 -  CR95HFDll_SendRec()
Thanks, Sasa
Posted on October 17, 2016 at 17:12
there is an Application note explaining how to develop a software to drive CR95HF board : AN3954 and associated source code example, available on
http://www.st.com/
AN3954 :
http://www.st.com/content/ccc/resource/technical/document/application_note/50/3e/09/39/51/a5/4c/3d/DM00034558.pdf/files/DM00034558.pdf/jcr:content/translations/en.DM00034558.pdf
Also available, source code examples (C & VB6) :
http://www.st.com/content/st_com/en/products/embedded-software/st25-nfc-rfid-software/stsw-95hf002.html
 Best regards
ST customer support
Thanks, Sasa
http://www.st.com/
AN3954 :
 Best regards
ST customer support
Thanks, Sasa
