I want to measure the magnitude of the voltage of the energy captured by the X-NUCLEO-NFC07A1 antenn
FGang
Can the antenna of this board be led out for measurement? How do I lead out the line for measurement? If not do I need to rebuild the board?
JDEME
You can find the gerber files here X-NUCLEO-NFC07A1 - Dynamic NFC/RFID tag IC expansion board based on ST25DV64KC for STM32 Nucleo - STMicroelectronics
Up to you to cut the antenna, the original design did not take in count  this possibility.
JDEME
