Demodulator output -EVAL ST95HF
Preetha Muralidharan
Posted on May 25, 2018 at 17:54
I am using  EVAL-ST95HF board and would want to see the demodulated signal using the oscilloscope. There's a Test Point-ST1 on board. Is that the de-modulator output pin?
I have attached an image for your reference.
Looking forward to hearing from you soon.
Thanks,
Preetha
#st95hf
Posted on June 04, 2018 at 11:18
Hi Preetha,
No, there are no way to get the demolutator output on the boards.
BR
PB
3 REPLIES 3
Posted on May 31, 2018 at 13:54
Hello Prethaa,
Unfortunately this IO is not the demodulator output and their are no pins that reflect in functional the internal signal.
PB
Posted on May 31, 2018 at 14:44
Hi Peter,
Thanks for your reply. Is there any method to check the demodulator output (using software)?
Thanks,
Preetha
Hi Preetha,
BR
PB
