2023-04-25 08:32 AM
We are using the CR95HF over SPI and communicating with a single NTAG213 tag.
I can successfully configure the reader and read 4 pages of user memory reliably using the READ command:
00 04 03 30 04 28. // Reads 16 bytes from Addr 0x04
We would like to read multiple blocks using the FAST_READ command but the following command structure gives an 0x87 error;
00 04 04 3A 04 07 28
Any idea why this doesn't work?
2023-04-25 09:18 AM
I've tried the 04 04 3A 04 07 28 command on my side and I've received:
80 15 30 30 30 30 32 38 FF FF 06 FF FF FF 07 FF FF FF A4 A5 08 00 00
Can you check the Frame Delay Time in your protocolSelect command? It should be at least T_ACK/NACK (see the Tag Datasheet).
Rgds
BT
2023-04-25 09:18 AM
Rgds
BT
2023-04-25 01:26 PM
The increased T_ACK helped - thank you!
Tony
