zquan.1
Visitor II
July 3, 2021
X-CUBE-SPN7, speed calculation,counter_ARR_Bemf = __HAL_TIM_GetCounter(&LF_TIMx); The variable counter_ARR_Bemf is step_time ? why El_Speed_Hz = (int32_t)((SIXSTEP_parameters.SYSCLK_frequency)/(prsc))/(__HAL_TIM_GetAutoreload(&LF_TIMx)*6);
  • July 3, 2021
  • 1 reply
  • 560 views
I can speak English ​ a little, sorry!
1 reply
Cristiana SCARAMEL
Hi @zquan.1​ and welcome to the ST Community.
The variable counter_ARR_Bemf store the last value of Autoreload for Low Frequency timer
With El_Speed_Hz = (int32_t)((SIXSTEP_parameters.SYSCLK_frequency)/(prsc))/(__HAL_TIM_GetAutoreload(&LF_TIMx)*6);
you get the *Eletrical* Motor Speed from ARR value of Commutation / LF TIM
I hope these info can help you; if so, consider to mark it as best answer by clicking the label "Select as Best".
"If you feel a post has answered your question, please click ""Accept as Solution"""
Cristiana SCARAMEL
Hi @zquan.1​,
my reply solved your doubts?
