2020-12-15 10:49 PM
Hi guys,
How can i solve the problem that motor vibration in zero speed? i'm using G431B board T-MOTOR 2312 and hall sensor(120 degree), set to torque mode, the motor work fine most time, but it will be vibration when start-up with heavy load or i stop the motor with my hand.
Is that normal? i did not see this problem in other foc drivers like VESC or odrive.
Really appreciated for any help.
