2024-10-16 8:13 AM - last edited on 2024-10-16 8:30 AM by Peter BENSCH
What is the difference between STGIB10CH60TS-L and STGIB10CH60TS-LZ? The difference Z.
2024-10-16 8:38 AM
Welcome @ST1345, to the community!
both devices are pin-compatible and have identical data apart from a small difference: in comparison to the STGIB10CH60TS-L the STGIB10CH60TS-LZ also contains embedded TVS to enhance ESD protection, which is also mentioned in it's data sheet, page 1.
Does it answer your question?
/Peter
2024-10-16 8:38 AM
/Peter
