Viper01 or Viper0P startup voltage
thansen
Is it possible to start either of these Vipers up earlier than their stated HV startup voltage by sourcing VCC manually (external supply) from the Vin voltage?
Peter BENSCH
Yes, you can do that.
/Peter
thansen
Thanks for confirming that. This means I can also use the Viper0P which will greatly improve my standby/"off" current consumption.
I just need to know the behavior when Vin is first supplied. Will it start in ON or OFF (ZPM) mode ?
How does the Viper behave in a no-load situation?
