TwisterSIM unstable on Win7
JFour.4
TwisterSIM becomes unstable after second simulation. Plotter interface hangs and becomes unusable... Got to close whole program and start again. (Win7)
Anyone knowing about that trouble ? Workaround ?
Thank you.
JFour.4
+1 up.
No one got this trouble ?
​Hello Jeanpierre, probably the issue is due to an huge amount of data involved in that specific simulation. If the step size is small (~0.1us or less) and/or the parameter "write data every" is low, simulation lasting seconds requires a lot of memory. In this case is often enough to wait that simulation is completed.
