2025-06-13 7:04 AM
Is there a way to set up the Sink PDO to take in a variable voltage?
I would like to set up
PDO2 5-20V 3Amps
PDO3 5-20V 5Amps
My plan is to use the Power Ok GPIOs to determine how much current I have and do some down stream current limiting.
2025-10-27 9:37 AM
Dear mreilly,
Sorry for the late answer, I missed your question.
No, it is not possible to program a variable voltage inside the STUSB4500.
2025-10-27 9:37 AM
Dear mreilly,
