ekocakaya
STSPIN32F0 and STEVAL-SPINS3201 Problem
  • May 3, 2019
  • 1 reply
  • 556 views
Hello friends,
I made a custom STSPIN32F0 board , copy all sames STEVAL-SPINS3201 except STM32F103 side ,
We upload default software from motor library and system works well in EVM SPINS3201 but when we upload same software to our boards , there is no movements,
When we checks registers, system stuck in FAULT_OVER or IDLE mode, system not turn to RUN mode
What is the problem can be? we checked all board , there is no difference with EVM board
Any idea?
1 reply
cedric h1
Visitor II
May 13, 2019
Do you have an UART connection with your board ? If yes are you able to connect with motorcontrol workbench ?
Did you check that your code reach the while loop in the main.c ?
Cedric
If you agree with my answer, please accept it by clicking on 'Accept as solution'.""
