Pierpaolo Tentoni
Visitor II
July 2, 2018
STSPIN250 EN/FAULT pin
  • July 2, 2018
  • 0 replies
  • 457 views
Posted on July 02, 2018 at 16:43
Hi, I'm designing an electronic board to control 5 DC motors using 5 pieces of STSPIN250.
The microcontroller that drives the motors does not have many pins so I would like to save someone by connecting all the EN / FAULT signals in parallel but I'm not sure if this connection is correct.
Can someone help me?
Clearly, connecting them all in parallel, in case of fault I would have only the overall information that one of the engines had a problem but for this project it is sufficient
