STSPIN Servo drive
Paul Strotten
Posted on March 10, 2017 at 14:31
Hi would it be possible to use STSPIN3201 to build BLDC servo drive.
Basic spec step and direction input, quad encoder input.
 Any help greatly appreciated.
Thanks Paul
Imen.D
Posted on March 13, 2017 at 16:04
You may refer to the
http://www.st.com/content/st_com/en/products/motor-drivers/brushless-dc-motor-drivers/stspin32f0.html
and refer to the application note and user manual that can helps you on this topic.
http://www.st.com/content/ccc/resource/technical/document/user_manual/group0/8d/d3/26/5a/91/e5/4e/44/DM00347450/files/DM00347450.pdf/jcr:content/translations/en.DM00347450.pdf
User manual Getting started with the STSPIN32F0 FOC firmware example STSW-SPIN3201
Imen
Imen
Posted on March 15, 2017 at 00:10
Thanks for your reply, re info think been though all your data sheets and info.
When using quad encoder with your STeval 3201 board found conflict with current sense pins.
Was hopping someone had done a BLDC servo drive using STSPIN3201.
Please do you have any code using quad encoder and step and direction inputs for position servo drive.
Or do you think this to much for this IC.
Please note this is a mass market project.
Have spent  about £30k and 3years work.
Am only 1 man band but working hard to get this done.
Kind regards Paul
Posted on March 20, 2017 at 14:53
Hi Paul,
which conflict you found in the encoder configuration with the current sensing pins?
Current sensing is operated on PA3/4/5 and quadrature encoder inputs can be mapped on PA0/1 (TIM2).
