stm32 sensorless 24v brushed dc motor control
irmakci
Posted on November 26, 2010 at 23:19
4 REPLIES 4
irmakci
Posted on May 17, 2011 at 10:20
And also how can i find FOC GUI software?. I downloaded for along time ago. But it is not available any more?on ST site.
irmakci
any answer?
muratterzi2
first off all you must use single pwm channel to drive power mosfet with a mosfet predriver. ifyou want control direction another output pin can be arranged for direction information. in that case you must use a hbridge dc motor power circuitry.if you want control mmotor torque adaptively you can add a resistor between ground and mosfet. and you connect that pin wit a suitable current sense amplifier circuitry to adc input of mcu. you ccan change pwm freq according to current across on motor.
there a a lot of simple aplication codes at section examples library adc and pwm. you can adapt that codes for your aplication.
bille.stello
FOC GUI refers to sensorless control of brush-less BLDC motor. Is that what you ment?
By the way, it's still on the web, you can find it for instance at
http://www.st.com/internet/mcu/product/164495.jsp
Billino
