STLA02, In the datasheet I have seen the resistor value is calculated as per for feedback voltage.How I can control the booster voltage.What is the Voltage at the Vout pin.
VVelu
STLA02, In the datasheet I have seen the resistor value is calculated as per for feedback voltage(200mV).How I can control the booster voltage.What is the Voltage at the Vout pin.How the resistor value is calculated.Let me know the feedback for the same.
0 REPLIES 0
