STEVAL STWBC86TX programming
DEIQO
Hello, I'm developing a wireless charger based on the STEVAL-STWBC86TX. When designing a new PCB based on the evaluation board, would it be possible to use the I2C converter of the STEVAL-STWBC86TX by removing the jumpers in order to program the new PCB?
1 REPLY 1
willzhou
Hi Deiver
Yes you can remove jumper and use for new pcb board to download fw.
also you can use MCU to download fw
Mcu C drive code:
GitHub - STMicroelectronics/STWirelessCharging-C-Drivers: Standard C platform-independent drivers for wireless charging ICs
