STEVAL-PTOOL2V1, I connected BLDC, 24V, downloaded STSW-PTOOL2V1 EVALSTSPIN32F0H25-HallSensors firmware to board. Motor is not spinning. What did I miss. Thank you.
ADani.2
Hi @ADani.2​,
if these info are useful to you, please "Select as Best" button to close the topic.
If you feel a post has answered your question, please click "Accept as Solution"
Cristiana SCARAMEL
Hello @ADani.2​,
the STEVAL-PTOOL2V1 is a reference design for power tools.
The driving method of this kind of application is the 6-step with position feedback from phase Hall-effect sensors.
The board is configured with a single shunt sensing topology and a companion STSW-PTOOL2V1 firmware is provided for evaluation.
I suggest to develop your application using the STSW-PTOOL2V1 firmware example package as starting point.
You can find more details on the board user manual UM2772 and firmware user manual UM2788
Let me know if these info are useful to use the STEVAL-PTOOL2V1.
Thank you.
*Avinoam Danieli * Senior Electrical Engineer
Hi @ADani.2​,
