STEF01 - Current Limit
FKell.2
the current limit resistor is recommended to be not greater than 1k, which equals a current limitation of approx. 1.3A. I would like to use the STEF01 in an application that requires a current limit of 1.0A.
Is it possible to further increase the value of RLim above the recommended values to decrease the current limit?
0 REPLIES 0
