2021-09-30 01:35 PM
Hi, I would like to adjust OCV parameter in STC3115.
In datasheet I see equation for calculation OCVtab value.
But I don`t understand it. If I have STC3115IQT and I can set 100% SOC from 4.313 V to 4.22V.
(4.22-4.313)/0.55 = 0.05 but to register I can only set numbers from -127 to 127 .
Please how can I correctly calculate OCV offset value.
thx
2024-05-27 02:59 AM
Hi lorant124;
I have the same issue. Did you get any solution to adjust the 4.2v with STC3115IQT?
Thanks in advance.
