STEF12PUR
Not applicable
Hello
I want to use STEF12PUR (electronic for 12V) and have following question:
1. What is the response time of this fuse (how fast it will trip in case of over current)?
2. For me not clear difference between ILIM and ISHORT?
3. If I want to set fuse for 2A according paragraph 5.2 I have to use 47.5 ohm resistor (by using formula: 95/2A = 47.5 ohm). But why graph 13 shows much higher values for this resistance - ILIM seems to be even ~3A?
Thank you.
Alex
0 REPLIES 0
